587,986 active members*
4,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 stock motor speed control question. New BOB has PWM out 0 to 10. Will it work??
    Aug 2007
    53
    Hi Everyone,
    Working on finishing my build in another thread but have a question about the BOB I'm using. It has a PWM output 0 to 10 volts and a relay. I have searched and read all the threads I can find and the question on Mach3 motor control for the X2 isn't clear to me. You can see the BOB on the automation technologies site. It's the KL-DB25-5, BREAKOUT BOARD WITH OPTICAL ISOLATED FOR STEPPER MOTOR DRIVER MACH3,WITH RELAY AND PWM SPINDLE CONTROL.
    Specs say 0-10V analog voltage output P1 port, P1 as PWM outputs can be controlled with optocoupler input spindle control.
    Since this board has the ability do I still need another control board or does the optocoupler part mean I need an optocoupler between the BOB and the motor control on the X2?
    I get the impression from the other threads that since the power supplies for the electronics in the X2 and the BOB are not the same that the ground reference is different and it lets the blue genie out of the bottle if hooked direct.
    If someone could give a clear answer on how to do this correctly and why it would be great.
    Thanks everyone.
    Sep 2009
    1856
    Re: X2 stock motor speed control question. New BOB has PWM out 0 to 10. Will it work?
    search x2 speed control G540. there is a write up where it was done with a g540
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Aug 2007
    53
    It's not real clear if that will work with the BOB I'm using.
    Sep 2009
    1856
    the G540 is 0 - 10. the connections should be the same most bob are the same
    [SIGPIC][/SIGPIC]
  1. 180V DC Motor Speed control Neco speed controller card - PLEASE HELP
    By gridevolver in forum CNC Machine Related Electronics
    Last Post: 01-22-2019, 06:44 PM
  2. PWM speed control help/motor help
    By 109jb in forum CNC Machine Related Electronics
    Last Post: 03-12-2015, 07:34 PM
  3. Replies: 4
    Last Post: 12-13-2011, 07:32 PM
  4. DC motor control for 180v dc motor, will this work ?
    By carl0s in forum CNC Machine Related Electronics
    Last Post: 04-15-2010, 01:31 AM
  5. speed control for this motor
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 04:28 AM
