I had an incident yesterday where my X axis stepper lost it's "grip" so to speak. That is it lost its orientation by a number of steps and it wasn't "locked" when not in motion. The ball rod could be turned somewhat easily when the motor should have been holding it in place. I have Superior Elect. SLO-SYN stepper motors with Superior MD808 drives. This happened after the CNC had been running for a while and my Z had dropped down a couple of thousands. I had to stop the program and re-wind the code to start over, when doing this I noticed the X had also lost...or gained a few hundredths. I have occasionally had this problem with my Z dropping a couple of thousands during a large file which puts a line across my work piece. I have also had the same problem with my X on rare occasion and only on large files. Could this be the drives or steppers? Could heat be a factor? I have been meaning to build a temp controlled, positive pressure box to house my computer, power supply and drives but still have them sitting on top of my CNC in the heat...and dust of my shop. Just a note...I have the jog set up extremely slow for zero-ing out for set up. Could this be causing me problems? Any advice or opinions would be appreciated. Anyone also know of a good source for these drives and steppers? I can't afford down time and would like to keep some on hand as spares. Thanks.
--Rick
