603,953 active members*
2,845 visitors online*
Results 1 to 4 of 4
    Jan 2004
    187
    stepper drive help
    Hi
    can anyone advise (in laymen terms) please.
    I have an old matchmaker mill and would like to convert to running from a PC.
    the motors are Superior Electric. U.S.A. ,2.1V ,9.2amps, 840 oz ,200 steps per rev. slo-syn class B synchronous stepping 5/8" dia shaft. the machine did run of a Posidata control,but the drive boards give nothing but trouble.
    can anyone suggest manufacturers for parts.
    thanks
    Brian
    BR
    Apr 2004
    439
    gecko makes a 7amp controller. that might work. it would limit your torque (oz's)
    but i saw he is coming out with a new "G204V " version. Sometime. not sure when you plan on buying. but maybe give hem a email or he might check this forum. See if he is going to be uping the amps on it
    geckodrive.com
    Apr 2004
    678
    www.phytron.de Look for SP-Mini. I'm satisfied with it, and impressed with their prompt technical support. It's just the right size for your motor.
    Oh! And tell them CNCzone.com sent you!
    Jan 2004
    187
    Thanks guys,
    brian
    BR
  1. Direct drive with stepper on rack and pinion.
    By jerryrigge in forum Linear and Rotary Motion
    Last Post: 10-10-2007, 03:21 AM
  2. Stepper As A Lathe Spindle Drive
    By mklb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-18-2007, 04:47 AM
  3. Stepper drive question
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 03:55 AM
  4. Need a low cost 4 amp, 48 volt, stepper drive
    By Mini Miller in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 08:29 PM
  5. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
