587,980 active members*
3,918 visitors online*
Thread: Watt choice
    Oct 2008
    10
    Watt choice
    Hello everyone, I am considering the purchase of a laser cutting / engraving machine, i would mostly cut 2mm wood and engrave on plaques and plastic (Plexiglass and such).
    Now the manufacturer of the laser cutter (Gravograph) is asking me if i want to go with the 30 or the 55 watt and honestly i have some troubles deciding.
    the question is...would the 30 Watt be enough?? Or the 6K upgrade to 55 is well worthed and.....required?
    I am considering this machine for work (i own a typography) so it would be turned on 8 hours a day for 5 days a week (that depending on request of course)
    So why should i choose 55 ....and what reason would make 30W enough?
    Drew
    Jul 2007
    78
    The 30 watt will cut your 2mm material wood fine. For engraving the power makes little difference between the two.
    If however, you may eventually want to cut thicker material, you'd need more power. Also, if you get large production cut jobs, the higher power allows for cutting at a faster speed, and save a lot of time. I have 45 watts and find it great for most jobs, but if I had less much of my work would take a lot longer
    since a good percentage of it is cutting 6mm acrylic. I can run it at speed 8, while the same machine with 30 watts would have to run on speed 3.
  1. Coherent 150 watt
    By funidea in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2012, 07:42 PM
  2. 50 Watt CO2
    By kdoney in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2007, 09:12 PM
  3. 60 watt engraver- opinons?
    By replicapro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-15-2007, 01:41 AM
  4. What will 50 watt cut?
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-11-2007, 09:06 PM
  5. 1400 watt UPS's
    By dneisler in forum CNC Machine Related Electronics
    Last Post: 01-22-2007, 03:20 PM
