587,333 active members*
3,588 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Intersection curves, V32
    Sep 2012
    76
    I used to use this all the time, but after an hour in the documentation, I am unable to find it in the 'Modify Group' of 'Create 3D'. Where did I go for my stupid pill????
    Mar 2012
    1570
    Re: Intersection curves, V32
    This should help.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Sep 2012
    76
    Yes, but I remember that I used to get a wire frame from it. What we do is take the wire frame, and extrude it another .5" so the 4th axis runs all the way to the end of the part. I used to do this, and darn I forgot how. Section did work, but I remember using intersection because teh section function was a little squirrely.
    Thanks for your reply.
    Mar 2012
    1570
    Did a quick youtube search and came up with this old video.
    https://youtu.be/oN_eP-en13w
    Al DePoalo
    Sep 2012
    76
    Well, thanks - what happened is the Intersection Curves was not on the ribbon at all! Why I do not know, but I added it all all works as it should. I was tearing my hair out looking for it on the tool bar!
  1. Line Intersection Problem
    By wxgeek in forum BobCad-Cam
    Last Post: 12-05-2013, 05:36 PM
  2. STL intersection
    By gallenat0r in forum BobCad-Cam
    Last Post: 10-24-2013, 05:14 AM
  3. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  4. 3D sketch from intersection curve
    By atlantic23 in forum Solidworks
    Last Post: 10-03-2010, 08:48 PM
  5. Error 509 arc lack intersection
    By dresda in forum Milltronics
    Last Post: 11-02-2009, 11:23 PM
