587,656 active members*
6,716 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Pocketing same width as tool diameter
    Oct 2012
    I am new to Rhinocam and CAM in general. I am trying to run a quater inch groove uning the pocket MOP Rhinocam 2 wont generate a tool path I presume because the tool diameter is quater inch. I have run and cut some pockets but have not managed to figure out cutting the simple grooves. Any advice would be appreciated
    sincerely
    David Kraft
    Sep 2012
    1543
    I think I know what you mean, and engraving would be what your trying to do. It will follow the line or curve as it were.
    Oct 2012
    Thanks, I'll try engraving. Do you know of a text or font comprised of a single line that could be used. most of the fonts seem to produce double lined texs objects in Rhino, I would like a standard flat mill to follow the centerline of the script rather than pocketing between the double lines of a script object.
    Sep 2012
    1543
    No, I've been looking into that aswell, I downloaded a program that does fonts to gcode, but haven't used it much as I can't accurately size the font.
    Research each tool path type in rhino to understand when to use what and how it works.
    Sep 2004
    107
    There's a link to a dropbox file with single stroke fonts on this page
    Rhinoceros » Single-line fonts in Rhino
    cheers,
    Michael
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. Selecting cut off tool width
    By wmpy in forum MetalWork Discussion
    Last Post: 10-27-2010, 05:30 AM
  3. Help: pocket width = cutter width
    By Clot in forum Mastercam
    Last Post: 11-03-2008, 02:20 AM
  4. CAM programs that do automatic multi-tool pocketing
    By jemmyell in forum Uncategorised CAM Discussion
    Last Post: 03-12-2008, 09:08 PM
  5. Pocketing and tool sizes
    By jderou in forum BobCad-Cam
    Last Post: 08-31-2004, 07:26 PM
