![Quote](images/misc/quote_icon.png)
Originally Posted by
dhardt
Notice the schematic, where -QF23 is, there is a D2/1.7
Now notice the SHEET NO. to the right of the DRG. NO. of LF00E0980
That SHEET NO. is 139
Above the 139 is a designation of =. M3 sh.1
Turn toward the front of the book to SHEET NO. 36
Notice that the 36 has a =.D2 sh. 1 above it.
Notice the numbers 1 through 8 across the top and bottom of the page. These are column numbers.
We are on Section D2, Sheet 1, and we want to look at column 7
Notice that -QF23 is the overload breaker for:
AC 110V Control circuit
(Contactor, Relay, Valves control)
this is a 7 amp trip.
if there is MORE than 7 amps going through the breaker, then the breaker is doing its job...find the short and fix it.
If there is LESS than 7 amps (significantly) then the breaker is faulty, replace it.
No insult intended:
If I need to go into more data as to how to diagnose this, you shouldn't be doing it.
