588,578 active members*
12,537 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > micro ATX power supply wiring question
Results 1 to 6 of 6
    Aug 2004
    41
    Cool micro ATX power supply wiring question
    I bought a 50W Touch micro ATX (SP9627) PSU. I cannot seem to figure out the wiring arrangement. I looked at the formfactor spec. It would seem to indicate that there should at least be standby power even when "off", but I cannot seem to find it. The connector is a 24 pin (2x12) connector, slightly different shape than the standard calls up (no locating "rib").
    There is a 3 position connector for the power switch... I jumpered a pair of the terminals and that started the PSU.
    Can someone tell me how to wake this thing up? Thanks!
    24221
    Albert E.
    Aug 2004
    41
    Wink
    Looks promising!... I'll give it a try tomorrow!.... P.S. Thanks for the link for the divide-by-N jamin'... Eric
    Mar 2007
    12
    Make sure you have sufficient load on this supply - on the +5v and I forget maybe the 12v as well. I usually connect an old hard disk and a load resistor on the +5v - It's a switcher and running without a load will damage the supply.
    Aug 2004
    41
    Red face
    Might be too late for this one? I already started (maybe... the fan was running) the PSU without load... It does not have a HD connector. Just a 4 pinconnector for a MB?
    The other connector is a 12 pin... not 24 pin as I had thought first. No green wire.. On the 12 pi, I have a bunch of black wires; one yellow; one orange; one white and three red. Further comments?
    Mar 2007
    12
    Typically there are a couple four-pin connectors for the disks (floppy, hard disk etc) and a larger connector for the motherboard, which varies. I'm not up on all the different configurations, but there are several sights out there with info. Here are a few I have used in the past:
    Be careful, this is not simple linear stuff; it's serious and dangerous!!
    Pin outs
    http://www.pcguide.com/ref/power/sup...erboard-c.html
    Repair (try General SMPS Troubleshooting Approach section for typical load)
    http://www.repairfaq.org/sam/smpsfaq.htm
    Theory
    http://www.onsemi.com/pub/Collateral/SMPSRM-D.PDF
    I hope this helps
    Mike
  1. Star wiring & microswitch power supply
    By szynszyl in forum Gecko Drives
    Last Post: 04-16-2007, 10:20 PM
  2. Power supply question
    By ruttkowb in forum CNC Machine Related Electronics
    Last Post: 02-19-2007, 03:01 PM
  3. Step Motor Driver and Power Supply Wiring
    By mcan in forum Open Source Controller Boards
    Last Post: 01-19-2007, 11:22 AM
  4. Power supply wiring help needed
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 10-27-2005, 05:05 AM
  5. New power supply question?
    By Redline in forum Stepper Motors / Drives
    Last Post: 07-23-2005, 08:08 PM
