070627-2236 EST USA
Do you make use of the HAAS RS232 SEND ALL capability?
If so, then how do you make use of the resulting file or files?
070627-2236 EST USA
I have never tried it. I have just picked and sent one at a time. Its sort of like "delete all?" I don't like "all" of any thing
I was at a HFO open house once, while one of the demo mills was in between parts...one of the sales guys was trying to show me a editing trick. He got to going too fast and hit "delete all?" (nuts)
It was a 3 axis part that was pretty involved and they didn't have a copy....
We use the WRITE ALL to floppy (or whatever it is called) on a weekly basis, more or less. It is simply a back up, all our programs are kept in the machines so we back them up onto floppy and onto a PC hard drive just in case the machine goes down.
So far we have never needed the back up.
070628-0603 EST USA
Kool Parts:
How much time do you spend to send 100 individual programs?
This is an interesting issue. I do a LOT pf prototyping. I NEVER save NC files. Never. I never edit anything at the machine. Never. It's all done at the cam system. I have spent a lot of time and effort to get my post processors working correctly. It has paid off in that I NEVER send any program back from teh machine. I save about 10 hours a week this way.
Don't know never tried it. But by the question I ASSume that you want/need to.
If that is the case I guess the question is..do you feel lucky?
I would ASSume that it would be harmless...but in my case that would mean the machine, 232 cable, and the computer would burst into flames simultaneously
Could you do it like a floppy backup? LIST PROGRAM, END, highlight ALL, WRITE, type a file name and then send it? That is how we back up all the Parameters Settings etc to floppy using the F2 key.
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
070628-0755 EST USA
Kool Tool:
If programs are short, and assuming 15 to 30 sec per program, then the time for 100 programs is about:
To floppy 25 to 50 minutes. Only 8.3 filenames are available.
To computer 100 ft away, about 4 miles of walking, add about 1.3 hours.
Realistically this time per program is probably too little.
A save ALL for 1 megabyte is about 1.5 minutes thru RS232 at 115.2 kbaud.
