588,354 active members*
7,805 visitors online*
Results 1 to 9 of 9
    Mar 2007
    3
    Fanuc 15T Backup Information
    Hi there, I wonder if anyone can help me. I am taking a backup of my CNC lathe and already have the parameters. Is there a way I can output the diagnosis pages. I remember a long time ago on another control and machine (Fanuc OT) there was a sequence of button presses to output the diagnostic pages along with the parameters. Is this the case with ths control or do I need to write them all down by hand? Thaks in advance.
    Dec 2003
    24220
    Why do you want to output the diagnostics? they change constantly or depend on machine function.
    Al.
    Albert E.
    Mar 2007
    3
    Quote Originally Posted by Al_The_Man View Post
    Al.
    I'm sorry I've made a mistake. It's the PMC Parameters and Ladder I want to save. When I go to the PMC side there is no I/O softkey option to get to the Write/Read page. Is this protected by keep relay or something?
    Dec 2003
    24220
    It depends on what PMC card configuration you have, The PMC may not be volatile if it is written in EEprom.
    Was the intention of saving for back up purposes?
    Al.
    Albert E.
    Mar 2007
    3
    Al.
    Yes, that's the intention. Do I not need to do it?
    Dec 2003
    24220
    If you have a Yellow Cassette sticking out of one of the Base cards, then there is eeproms inside, the machine only uses these to load into memory at power-on time.
    You could actually remove the cassette, after power up and run, but as soon as you power down you lose the PMC. If you do not have the yellow cassette then you could have battery backed up ROM, but doubtfull.
    Al.
    Albert E.
    Nov 2012
    10
    Sorry guys,
    What if the system has a yellow box" cassette" and there are also batteries in the cabinet, than where would the software be stored ?
    What happens if these batteries are dead ? which data will be lost system or parameters ?
    Dec 2003
    24220
    Parameters, including the 9000 option parameters.
    And macro's.
    Al.
    Albert E.
    Oct 2009
    297
    On a 15A control you will lose CNC parameters, Programs including 9000, offsets, Macros, pitch error, PMC parameters( Timers, Counters, Keep Relays, Data). You will not lose the Ladder program.
    Alex
  1. Mazak M32 system disk backup
    By sivaraj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-25-2017, 10:41 PM
  2. Example CNC machine Setup Sheet + program backup
    By lug_wrench in forum DNC Problems and Solutions
    Last Post: 12-28-2015, 06:37 PM
  3. backup program of T1 and M1 to PC
    By vpkurt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2007, 08:15 AM
  4. Saving Mach3 Settings as backup?
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2006, 03:02 PM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
