588,383 active members*
4,785 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 4th axis continuous machining software?
    Jun 2004
    201
    What program will do 4 axis continuous machining?
    Meaning you have a 3d model of lets say a persons head and you want to machine it into a block of aluminum. Most programs make you index and slightly turn the table then run a roughing code then repeat.
    Is there something that can take into account the safe zones and not run into the edges of the stock?
    Nov 2003
    244
    Visualmill and rhinocam are two that I know of.
    ...He who makes no mistakes makes nothing! ...
    Tom
    Mar 2005
    214
    DeskProto will too, but it only works with .stl's.
    Jan 2004
    3154
    Pretty much any CAM over $6500 will do it.
    OneCNC starts about there with 4 axis.
    Prices skyrocket pretty fast and don't forget a lot of the big buck guys also have yearly maintenance fees.
    BTW I use VisualMill
    www.integratedmechanical.ca
    May 2007
    781
    There is the CNC Toolkit for GMAX does 4 and 5 axis stuff.
    http://www.rainnea.com/cnc.htm
    http://groups.yahoo.com/group/CNC_To...guid=113406470
    Not commercial grade software last I looked at it but it can be made to work and it is cheap.
  1. Software for simultaneous 5 axis machining
    By mudasser in forum Uncategorised CAM Discussion
    Last Post: 02-21-2008, 06:23 AM
  2. can't continuous jog in mach 3
    By fbmstar in forum Mach Software (ArtSoft software)
    Last Post: 11-19-2007, 02:56 AM
  3. 5 Axis indexed vs 5 Axis continuous
    By jwolin in forum Uncategorised CAM Discussion
    Last Post: 03-24-2007, 08:21 AM
  4. Machining Software
    By Dzilli in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2005, 06:57 PM
  5. cam software for 3 axis machining
    By mtechserv in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2005, 09:35 PM
