I need to make the primary connections from 480 delta to a machine transformer.
Do I need to be concerned with phase sequence? If I connect the leads "backwards" on a motor, the motor spins in the wrong direction, which is easy to identify and change.
Can a transformer (480primary/210secondary) be connected in any sequence?
