![Quote](images/misc/quote_icon.png)
Originally Posted by
Bloy2004
Hi there...
Gee ...I missed this question....
The threaded rod is held in place by a taper pin that should drive out from right to left as it is on the machine. Then, the threaded shaft can be driven up and out as it is turned to 10mm on the inserted end(no threads). Be carefull to provide backup if doing this on the machine... The parts are pretty tight on mine.
Actually, to get the rod out after removing the pin, I grabbed it with a visegrip and twisted it up....didn't want to knock anything out of kilter.
