Can someone help me with programming 1/4 npt external using G76 (fanuc O-T). I do not know what values to put in for the thread dimensions. Thanks!
.54 dia start point with 1.75deg per side. Is it help.
The best way to learn is trial error.
I'm threading 1/4 npt threads on a fanuc ot controled cnc lathe. Can anyone give me some help on the second line of info using G76?
Lead is 18 threads per inch, taper is 0.0625" per inch diameter measure, finish diameter is around 0.56", length is around 1/2".
Thread ending point figured at center of 16ER 18 NPT insert and L4 dimension from Machinery's Handbook.
Finish turn .016R insert
X.3768Z0
G3X.4065Z-.0062R.021
G1X.5249Z-.0653
X.54Z-.3077
Z-?
Finish turn .031R insert
X.3468Z0
G3X.3977Z-.0105R.036
G1X.5245Z-.0739
X.54Z-.3224
Z-?
Thread 1/4-18 NPT external
X.58Z.3
G76P000155Q30
G76X.467Z-.634P444Q150R-.0291F.05556
Changing starting point or ending point will require R to be modified. R=tan(1+47/60)*(start point + end point) unless both points are the same sign, in which case you would subtract them.
Single block G76
X.58Z.3
G76X.467Z-.634I-.0291K.0444D150F.0556A50.
Did one of these work okay for you?
Apparently my examples didn't work. What did you finally wind up with?
