587,236 active members*
3,628 visitors online*
Results 1 to 16 of 16
    Mar 2012
    102
    First Turned Parts on SlantPro
    I've been working through some new profiles and learning the machine control. I have Sprut and Tormach was kind enough to give me a preview post so I could make some more complex parts. So far I have 4 or 5 part profiles CAM'd up with various drill, tap, external threads. I am in the middle of fabricating my parting tool holder so I'm not running very automated yet.
    The guys at Tormach have been great in helping me through some of the teething problems. Most have been easy fixes. I'm using the 5C manual closer and making extremely accurate shapes. I will post some images later.
    Nov 2007
    2151
    Re: First Turned Parts on SlantPro
    Nice!
    I guess by your note tormach is still working on the sprutcam post?
    Would enjoy seeing and reading more!
    md
    Jun 2006
    3063
    How accurate and reproducible are the dimensions for the parts you've made so far? How do you like the 5C closer?
    It's very good to hear that Tormach is working on a SprutCAM post. Do you know if they are working on a machine definition, like they've done for the 1100 mill? It was pretty neat the way they incorporated the rotary table and vertical/horizontal auxiliary spindles into that.
    Mike
    Sep 2009
    318
    After going out and buying bolts and I got my collet closer installed. How much does your handle vibrate when the machine is running and is a little vibration normal?
    Mar 2012
    102
    It vibrates a bit. I guess the most critical part is dialing in the flange plate on the pulley adapter. They told me to get it within a thou. I'm still at .01tir because of the 3 bolt system. It is not as straight forward as 4 since it twists when you tap it. This is a JKF issue I suppose. It can be done, just takes a bit of time.
    Sep 2009
    318
    It took me about 15 minutes of tapping on it to get it within .001. It would have been nice if they had designed it so there was a precision machined section to align it all on the back of the spindle. I went down to lowes and got a pin to replace the bolt so I can remove the closer easily.
    Mar 2012
    102
    Here is my new custom coolant setup for my gang. Needless to say, broken drill bits will ensue without a feed of coolant. I will eventually valve all of them.
    Mar 2012
    102
    Here are some of the parts I'm producing. I've run 50 of these so far on the lathe/mill. I blank them on the lathe and finish up the ports/flats on the comp in my 1100. I'm haven't gotten the rigid tapping figured out yet. I don't have a spiral fluted m9x.75 tap, and Sprut does not post rigid tapping yet. That's the only had operation.
    Nov 2007
    2151
    Nice!
    Do you save results from sprut lathe operations and use that as work piece for mill operations in sprut?
    md
    Mar 2012
    102
    No, the mill program was written a couple years ago. I just don't in the shank area so it's no different than when I blanked them manually.
    Jul 2004
    1424
    Muzzle brake?
    Looks nice, did you anodize of electroplate them?
    Mar 2012
    102
    Yes, we make accessories for the GSG 1911-22 pistols. We actually use Norrells Moly Resin. Quick than anodize and holds up great!
    Jun 2006
    3063
    Quote Originally Posted by menzzer37 View Post
    Through-the-tool coolant would be great for deep drilling and boring. Would that be possible to do with the Tormach gang tooling?
    Mike
    Mar 2012
    102
    Another part. Cranking out thread adapters in low carbon steel. Would love to have the bar puller running!
    Jun 2004
    6618
    And that is specifically why I bought the Tormach. It has room for a bar puller. I will let you know how all that works out.
    Lee
    Jun 2004
    6618
    Quote Originally Posted by compunerdy View Post
    You have a lathe now, make a precision alignment tool.
    Similar to a clutch alignment tool. I think the outer ring that needs aligned is just a bit larger than the inner one on the spindle. Problem is that you need it aligned before you can turn the alignment tool. Maybe Tormach could offer an installation accessory tool?
    I actually looked at this yesterday and the outer ring is just a bit smaller than the spindle opening. So with the chuck installed, one could possibly grind that part out a little bigger. I would like to see that setup.
    Lee
  1. RFQ Turned 6061 Parts
    By rxtreme in forum Employment Opportunity
    Last Post: 07-10-2015, 04:20 PM
  2. Turned Aluminum Parts
    By tdj.eng in forum North America RFQ's
    Last Post: 03-28-2014, 09:09 AM
  3. Need some brass parts turned RFQ
    By msloan in forum RFQ (Request for Quote)
    Last Post: 01-02-2012, 05:26 AM
  4. RFQ on turned steel parts
    By TheGreenMachine in forum Employment Opportunity
    Last Post: 11-12-2010, 07:15 PM
  5. RFQ - turned parts
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-01-2006, 04:57 AM
