588,297 active members*
4,986 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > mits 520am control geometry/wear offset even available?
    Sep 2005
    23
    Smile mits 520am control geometry/wear offset even available?
    does anyone know if this is even a option?
    all of our controls only have the one offset.
    would be nice if it had gemetry/wear offsets but i have never seen it.
    any info appreciated.
    Jan 2011
    It is possible to set the tool offsets to inlude a wear column.
    If you go to www. meau. com then downloads, you can
    get the M520 instruction manual. You will see what's referred to
    as "TOOL OFFSET MEMORY TYPE II"
    You will need to change a machine parameter that's outlined in the
    instruction manual.
    Sep 2005
    23
    Thanks.
    do have the manual.
    feel like a idiot - helps if i read it i guess.
    been looking everywhere else except the manual close enough.
    Aug 2012
    Is there a parameter change to have the wear offset reset to zero when its station is zero'd off ( on M50 L)
  1. Need Automatic Wear Offset
    By p8md in forum G-Code Programing
    Last Post: 10-22-2022, 03:43 AM
  2. wear offset not working!!
    By marcoagg3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2009, 11:35 PM
  3. MITS MELDAS 520AM trying to go to China!
    By acrodave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2009, 04:42 AM
  4. Tolls offset wear.
    By jdgromi in forum Fanuc
    Last Post: 04-23-2009, 01:16 PM
  5. wear offset missing
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2009, 05:35 PM
