New to CNC.......
I would like to know the difference between Bipolar Parallel, Bipolar Series and Unipolar stepper motors and why you would use one over the other
Thank you
New to CNC.......
Thank you
Here are 2 links...
http://www.solarbotics.net/library/p...f/motorbas.pdf
http://www.cs.uiowa.edu/~jones/step/types.html
Bipolar means that the current flows in both directions through the windings at different times. Unipolar means it only flows one direction through the windings at different times.
Wheather series or parallel depends on the motor leadout. A stepper with only 4 leads (bipolar) gives you no choice. A motor with 6 leads (unipolar) also gives you no choice as to series or parallel, but you can drive it bipolar by disregarding the center tap. An 8 lead motor (aka bifliar) gives you the choice of parallel/series and unipolar/bipolar.
Putting the windings in series doubles the resistance and the inductance, putting them in parallel halves the resistance and inductance.
There are tradeoffs with the different setups. In my opinion, bipolar parallel offers the best overall performance. But thats just my opinion.
Steve
Excellent info Steve
Much appreciated
