588,668 active members*
6,473 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Manual Tool Change - Dolphin CAM doesn't seem to follow settings
    Aug 2021
    27
    Hi
    I'm having issues with getting the Z height to follow the settings I've entered in the "Tool Change" dialog box with Partmaster 15 and Mach4.
    It seems that whatever I enter in the "Tool Change" settings it doesn't seem to be followed and the Z axis does not allow enough clearance to change the tool.
    This is a manual change situation.
    Any help would be appreciated.
    Phil
    Feb 2007
    414
    Re: Manual Tool Change - Dolphin CAM doesn't seem to follow settings
    Hello Phil,
    Could you send me the PartMaster CNC file file and tell me which post you are using ?
    Some posts have "hardwired" values
    andre@ dolphincadcam.com
    regards
    Andre
    Feb 2007
    414
    For the benefit of the forum, here is the reply to this question ......
    The post is using the CLEARPLANE to position the tool if the tool is not already at the Toolchange position…
    if ( $Z ne $ZTLOAD ) then
    #N " " (_G00) (_G28) $ZTLOAD:ZAXIS eob
    #N " " (_G49) EOB
    Endif
    #N " " (_G49) eob
    #N " " $TOOLNO:TOOL (_M06) " ( " $JOBTEXT " )" eob
    #N " " (_G00) (_G43) $CLEARP:ZAXIS $TLCNO:TLC eob
    So you can either modify the post ….. #N " " (_G00) (_G43) $ZTLOAD:ZAXIS $TLCNO:TLC eob
    Or set the Clearplane to the required value ….
    regards
    Andre
  1. MDI Doesn’t work after tool change?
    By Se5a in forum Fanuc
    Last Post: 02-18-2021, 05:46 PM
  2. Replies: 1
    Last Post: 08-13-2019, 08:36 PM
  3. HSK Style Tool Holder Manual Tool Change Spindles
    By tinmancarving in forum Spindles / VFD
    Last Post: 10-01-2018, 08:05 PM
  4. Benchman 4500 Change Manual Settings
    By kbrodrick in forum Benchtop Machines
    Last Post: 05-03-2012, 10:41 PM
  5. Multicam Router/Doesn't follow mastercam Z depths
    By jbcourt in forum Multicam Machines
    Last Post: 09-20-2011, 05:12 PM
