Material: 1.5" OD (38.1mm) x ~32mm ID aluminum tube (6061?). ie. 1.5" diameter with 3mm wall thickness.
Simple turning of the OD, nothing needed internally. Basically a 120mm long tube with the first 80mm turned down to 36mm OD, the rest skimmed off for a smooth finish, and some cosmetic grooves added (dimensions don't need to be accurate, just consistent).
Would like a nice clean finish on these, and preferably the sharp edges taken off a bit; not sure how to represent this on the drawing (I'm not a CAD person).
The design could be expanded to include some milling and drilling, depending on quotes.
Quantity: 5/10/50/100
I'm expecting to require about 20 of these a month if production goes ahead. There are several other required pieces to be quoted on in the future.
Location: I'm in Brisbane, Queensland, Australia, so would prefer an Aus based machinist, but depends on costing and time; I'm quite happy to receive bulk lots from overseas if the price is right and they can be delivered in a timely manner (I'll be working with a JIT production strategy, but can stockpile common parts like this one)
You can contact me via email: lee at baudalign dot com
and I'll be checking in here every now and then.
Design:
http://baudalign.com/lee/pics/rearCommon_new.pdf
Lee
