588,289 active members*
5,969 visitors online*
Thread: rapid speed
    Feb 2007
    48
    Unhappy rapid speed
    Good morning,
    I have a question about my rapid speed. I can only get about 20 inches per minute before my motors start to break up or stall. I am using a Xylotex 4 axis kit with 425 oz-in motors and 1/2-10 ACME thread. The motors react like this without any load as well. Every motor reacts the same, but I don't really know how to address the issue. The machine works great, but travel is very, very slow. Perhaps I am expecting too much, but it seems like everyone else has much better speed than I. Please advise.
    That's a common problem with the Xylotex. If you have dual shaft motors, one solution is to buy or build a damper to eliminate mid band resonance, which is most likely your problem.
    Another option is to switch to 2 start acme screws, 1/2-8 or 1/2-10, which will just about double your speed, but you'll still probably have resonance issues. I've seen a lot of posts saying that those motors can not be spun very fast with the Xylotex, due to resonance issues. The damper should haelp a lot.
    http://www.cnczone.com/forums/showth...639#post256639
    Feb 2007
    48
    Thanks, I am going to start making a set of these right now! Is there anything I can do with micro-stepping to help out with the resonance issue?
    You can try the different settings, and they may make a difference, but you'll need to try to see if it helps.
  1. Rapid to (# set by Parameter) What's yours?
    By Scott_bob in forum G-Code Programing
    Last Post: 09-01-2021, 06:05 PM
  2. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
  3. G-Zero by Rapid Output!!!!!
    By tobyaxis in forum Uncategorised CAM Discussion
    Last Post: 02-05-2007, 05:16 AM
  4. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
  5. New Taig, 8 ipm maximum rapid speed?
    By fivaxis in forum Taig Mills / Lathes
    Last Post: 05-11-2006, 02:55 PM
