I tried the diffrent tools and I can't get my over all length to take on the drawing.
Radius and diameter work, along with dimesions between two lines, just can't get the length for a cylinder.. (???)
Luke,
Maybe you need to extract an edge.
Or post the drawing for someone to look at.
Phil
Sent from my HTC Desire using Tapatalk
I want to measure the height of this part and have it shown on the screen.
I have the diameter and raduis but I dont know what tool to use for the height dimension.
Choose your circle quadrant snap point for the top and bottom circle for dim.
You'll need to change the construction plane to either XZ or YZ to be able to pick points lying in different Zs
GOT IT!
Changed the plane and added geometry to the top.
Thanks guys.
