588,268 active members*
10,672 visitors online*
    May 2007
    30
    Digitizing macro's
    Hi
    I am trying to get hold of some macros to digitize. I have a Haas mill id like to digitize something on.
    Any format will do, ie fanuc, haas, siemens, heidenhain etc etc
    Is there anyone who can help me.
    Thanks Mark
    May 2007
    30
    Bump
    Surely someone has done this before!
    Using a renishaw omp 40 and a haas vf2. Any programs appreciated, fanuc, siemens, fadel, hurco, heidenhain etc etc.
    Nov 2004
    6
    Digitizing Macros
    Mark,
    Just purchased a VF-3 with the opm-40 and am in the same boat. I downloaded
    the macro manual from renishaw but not knowledgeable enough to figure it out at this point. If you make any headway let me know.
    Good luck,
    Mike
    May 2007
    30
    Hi Mike
    The renishaw cycles will not help you. There are soe cycles for inspection, ie measuring bores etc, but none for digitizing. You will need to create your own cycles for digitizing using the G31 command and macros and outputting data through RS232.
    I created some digitizing cycles and VQC templates but for my own probing system, not sure how well it will work with the OMP40
    Sep 2005
    171
    You might go over to the Mach3 web site and check out their probing routines and macros, might give you some ideas.
  1. Haas Macro's
    By Tazzer in forum Haas Mills
    Last Post: 09-03-2007, 11:07 PM
  2. Macro's on Fanuc OT
    By pinguS in forum Fanuc
    Last Post: 09-23-2006, 10:51 PM
  3. Macro's for the masses
    By Equinox in forum G-Code Programing
    Last Post: 06-22-2006, 07:47 AM
  4. macro's
    By Traceycnc300 in forum Haas Mills
    Last Post: 04-17-2006, 06:43 PM
  5. How to use Macro's
    By smallplanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2005, 10:32 AM
