Hi All, Im new to cnc milling but have been using a Laser cnc for a while, I am looking to buy a cnc for cutting disks in 3-5mm perspex, I have been looking at the ebay cheap machines and would like to know which one is best for what i need. I do not need anything bigger than A4 cutting, but would go up to the 6040 machine, I see they vary in power and rpm the cheap ones are 230w and the more expensive are 800W water cooled, would 230W @8000RPM be suitable or would the 800W be better?
here are the specs for the more expensive one i was looking at. All help would be muchly appreciated!
6040 triaxial engraving machine part parameters:
- Effective working travel:400(X)mm*580(Y)mm*75(Z)mm
- Shape dimension:880*670*530mm
- Max.thickness of the materials:≤100mm(the distance between Z axis and the bottom of the working station)
- Max.workpiece dimension:750mm*450mm
- Work table dimension:750mm*480mm*20mm
- Frame materials:6061 aluminum alloy + 6063 Industrial aluminum
- Driving units X axis:NEW 1605 ball screws
- Driving units Y axis:NEW 1605 ball screws
- Driving units Z axis:NEW 1605 ball screws
- Sliding units X axisia.16mm chrome plate shafts
- Sliding units Y axisia.20mm chrome plate shafts
- Sliding units Z axisia.13mm chrome plate shafts
- Stepping motor type :57 two-phase 3A ,super-low noise ,NEW
- Spindle motor:0.8KW VFD spindle ,NEW
- Principal axis collet:ER11/3.175 collet
- Spindle speed:24000rpm/min (PWM stepless speed regulation)
- Empty line speed:0-4000mm/min
- Resetting accuracy:0.05mm
- Engraving accuracy:better than 0.04 mm (has been tested)
- Spindle precision:radial runout≤0.03mm
- Control unit:triaxial one-piece drive + ring variable power + PWM speed
- Carving Instructions:G code/TAB files/nc file/NCC files
- Communication interface:through parallel connection with computer
- Software environment:Windows 2000 / xp
- Carving speed:300-3500 mm/min (different materials differ)
- Machine weight:55 KG
Control box parameters:
- Operating Voltage:110V or 220V 50/60Hz(we also stock USA.UK.EU.AU.plugs.)
- Work theory:3977 3-axis control box with the power supply + spindle speed regulator
- Control unit:3A stepping motor driver plus adjustable spindle speed controller
- Computer connectionn board parallel port
- Command code:G code
- Acceptable software:Mach3,EMC2
- Protection:Emergency stop butto
