603,855 active members*
3,680 visitors online*
    Apr 2006
    512
    What paint for perspex???
    I am having problems painting Perspex. I have used a V cutter to cut football badges and using the backing plastic as a mask. The paint am using is acrylic Tamiya model paint. Unfortunately when carefully peeling away the backing plastic chunks of paint are lifting away. Undercost was used and light coats applied with an airbrush.
    Is their a more suitable paint or do I require some sort of etch primer????
    ive never dealt with perspex but have had the same probs with others you can use a self etching primer but i have found that plastic adhesion promoter tends to work nicely such as and adhesion promoter they use on automotive bumpers to keep paint from peeling i found the stuff i used at the local auto paint store it either comes by the quart or in a rattle can hope i helped
    "The best things said should be written in stone"
    Colton www.coltonscustoms.com
    Aug 2005
    828
    The best stuff is adhesion promoter called Bulldog. You can buy spraycan in walmart or autobody supplyer. Works great with plastic aluminum glass chrome.
    You can spray bulldog and while its wet spray paint.
    Dennis
  1. Machine paint? Where to get?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 10-29-2006, 04:04 AM
  2. Good metal paint
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 10-23-2006, 02:44 AM
  3. Best paint for CNC cabinet
    By Karl_T in forum MetalWork Discussion
    Last Post: 10-31-2005, 05:56 PM
  4. Paint Recommendation
    By ChrisJ in forum Vertical Mill, Lathe Project Log
    Last Post: 10-06-2005, 08:30 AM
  5. Paint that oil will not affect ?
    By Ken_Shea in forum Community Club House
    Last Post: 04-27-2004, 04:51 PM
