587,719 active members*
3,494 visitors online*
    Mar 2007
    23
    BEI encoder replacement
    This message is cross posted on several web sites. The Z axis on my Bridgeport BTC1 has acted up. Seems the encoder used (past tense) an incandescent bulb. I once found an editorial where someone replaced one of these can type BEI encoders with one of the new, miniature all solid state encoders. They had a complete pictorial on how to do it, although, as I recall, they didn't tell much about the bearings and what kind of hardware they had to use to adapt. Does anyone recall this article, and where it is? I'd love to ask the editor some questions.
    24220
    This may help, or search the B.P. section.
    http://www.cnczone.com/forums/bridge..._conversio.htm
    Al.
    Albert E.
    Sep 2010
    1765
    If link does not fix u up, why not list the motor and encoder part no for us? I've not found many an encoder yet we cannot replace with a drop in identical new model. email us with nos and we will look for replacement if you want. [email protected]
    Mar 2005
    78
    Re: BEI encoder replacement
    I wrote a replacement post in the BTC1 clubhouse Forum. It can be read here
    http://www.cnczone.com/forums/bridge...bhouse-21.html
  1. Obselete encoder replacement
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2017, 08:59 AM
  2. spindle encoder replacement
    By howd in forum Okuma
    Last Post: 07-01-2013, 02:45 PM
  3. encoder replacement
    By jedstudios in forum CNC Machine Related Electronics
    Last Post: 01-08-2013, 05:57 PM
  4. encoder replacement
    By emxaler in forum Okuma
    Last Post: 02-24-2010, 08:50 AM
  5. encoder replacement
    Last Post: 02-20-2010, 06:03 AM
