evening all,
does anyone know about the compatibility of emc2 with kelling inc.'s cnc 3 axis stepper package?
i'm a super-new-b looking to set up a little cnc machine. and, after doing a lot of research on building my own boards (and realizing i have a ton to learn), i'm settling on getting a pre-soldered setup. i have been lurking for a while in this and other sites, but haven't found any threads on using these 2 pieces of equipment together.
the keling setup (http://www.kelinginc.net/ThreeXCNCPackage2.html) runs via parallel port - so i know it's compatible in those terms most simple terms.
it looks like keling uses cnc4mypc's c10 breakout board (http://www.cnc4pc.com/Bidirectional_Breakout_Board.htm) for signal control, and that the board has jumper settings to allow pretty discrete control over pin input or output. this along with emc2's involved (hal?) level of signal control seem to make me think i should be able to route signals where ever they need to go.
so, i'm figuring that emc2 and the keling setup should be able to work together. but, since i'm a super-new-b i figure i'm missing something big. can anyone comment?
thanks much.
i really like all the knowledge people drop in here. this is awesome stuff.
