Delivery
After a bit of a wait, my Torus Pro (TP) finally arrived via freight. The delivery was in three large crates. The creates were easily moved into place with a 1500lbs pallet jack. Should have taken pictures, but had a kid in a candy store moment.
Un-crating
First impression left me awestruck as this mill is gigantic. Completely different than the X3, Rf-45, G0702 retrofit kits that I am used to.
- Pros: Everything was packed very well. No visible damage to any of the components (Pics 1-7).
- Cons: Only drawback here is that the mill did not come with a manual.:stickpoke Novakon emailed me a copy of the V2 manual which has a very similar assembly process. Novakon is working on a manual for the TP and will send it when able.
Assembling the Stand
Modification (Mod) 1: Everything in my shop is on casters. This aids my frequent shop redesigns. The TP comes with 6 beefy leveling shoes which are more than capable for the task (Pic 8) <- BUT THEY AREN'T MOBILE. Time for an upgrade! I bought six 2.5 inch leveling casters from accesscasters.com. First step was to cut off 3 inches of threaded rod from the stock levelers. Next, drill out the center to accept the M12x1.75 insert from the leveling casters (Pic 9). Then, thread the rod (Pic 10). Finally, red locktite the sections together (Pic 11). Here are the results (Pics 12 & 13). Now we have a completely mobile Torus Pro! :banana:
Mod Cost:
Casters: $28.76 ea x 6 = $172.56 (Expensive? Maybe, but hey you just spent $10,000+ on a mill; no turning back now)
