587,158 active members*
3,124 visitors online*
    Aug 2011
    617
    CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
    I went for the 50w machine, as it seemed a good deal.
    It stopped working.
    I am noticing 40w spec's are almost identical, but MUCH cheaper !
    So, I need to find out if it's the tube or supply that is broken.
    Can I buy a 40wPSU and use it with the 50w tube ?
    Then if it doesn't work, I will buy a 40w tube.
    Also in the future, the 40w will be cheaper each time I need to replace the tube (or supply)
    I plan on using the poor little machine, all day every day, once it's working again.
    Thanks in advance for any advice
    Rich
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Aug 2011
    617
    Re: CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
    Well... to answer my own question...
    Today, I fitted a 40w PSU and have been cutting for several hours without a problem.
    The power is down... I've had to increase the percentage, and slowed the speed, but apart from that it works, and has confirmed the old PSU was dead.
  1. any standard design to attach end of a tube to a plate & allow tube rotation?
    By cknicker in forum Mechanical Calculations/Engineering Design
    Last Post: 03-26-2014, 11:19 PM
  2. Tap holes in the end of aluminum tube, Tube will be provided
    By WRichards in forum North America RFQ's
    Last Post: 10-17-2012, 12:30 AM
  3. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  4. Difference between Chinese Glass tube and RF Tube...
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2012, 03:44 AM
  5. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
