I'm a little lost, so if I have missed a thread covering these topics, please just point me in the right direction.
I have been looking at several mills and searching through this board like crazy. I have found a few options, but here is the latest.
If I buy these three parts, will they work together with essentially basic assembly?
X2-Type Mill, Harbor Freight (this is the right one, correct?), $~500:
http://www.harborfreight.com/cpi/cta...emnumber=44991
This CNCFusion CNC Conversion kit, #4 $~575:
http://www.cncfusion.com/minimill1.html
The CNCBridges Table, $~600:
http://www.cncbridges.com/mmb85265.htm
And this motor / electronic kit (Nema23 motors is about all I can point out for comparison), $1625:
http://www.super-tech.com/root/itm.a...-emc-mightybox
Will those work together? If not, could you point me in the right direction to the parts that will work? Id like as "complete" a setup as possible, because I don't yet understand enough about the inner workings of these things to try to fabricate parts for them. And I definately don't understand the electronics enough to try to mix and match and tweak in that department.
This would be a grand total of about 3300, plus extras. If everything works like Im thinking, Id have by far the largest capacity of any mill Ive seen in this size or price range. The next step up seems to be the RF31-type mill (which seems to be available just about everywhere with different names and colors), or the X3, but with the CNCBridges table the X2-type would still outdo them in every direction (at least for the RF31).
I'm not so concerned about motor torque, as long as it won't effect the part quality or machine reliability. Rapid time isn't a huge deal, since after I get it going, I will be busy in other parts of the shop mostly, and only changing out materials on the table every few minutes or whatever after the parts are done.
Am I missing anything?
Thanks in advance!
