588,668 active members*
6,668 visitors online*
    Dec 2010
    201
    Rigidity issue?
    Well, the boss saw the little Griz...
    And he walked up, put one mighty paw on one end the table, and the other one on the top of the column, and commenced to wiggle a dial indicator about 10-15 thou...
    "It sucks."
    Was also showing some spindle runout until I torqued down the piece that the drawbar bolt goes through a bit... Uh, what is that thing called, and just how much can I tighten it down?
    Now, he's the kinda guy who won't use a 3/4" end mill if a 1.25" one will fit... And if a face mill is called for, just hide behind something... Fire it up, and make some big ol' chips...
    Right now, until I get more comfy with the concept, I'm just going to be doing the Phase I...
    Aug 2008
    187
    ah, if only they sold a Haas for 1k that could fit down the basement stairs, how impressed
    the real machinists would be.
    till then we make do.
    [ame=http://www.youtube.com/watch?v=X_6i4SN05HU&feature=plcp&context=C3b64e37U DOEgsToPDskL-On00HCOaTNfpDdSrtyiq]BF 30 column support - YouTube[/ame]
    Dec 2010
    201
    "I can move it with a hand truck" did not impress... I'm thinking I'm going to do the concrete mount trick...
    "Uh, dude... You know that little machine? You said you could pick it up and throw it? You're gonna need a bunch of riggers..."
  1. DIY CNC Rigidity/Flex
    By bassman2914 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-21-2018, 04:29 PM
  2. Tooling Rigidity
    By BobWarfield in forum MetalWork Discussion
    Last Post: 07-22-2010, 06:28 AM
  3. Sieg KX3 Rigidity
    By cowcowlee in forum Benchtop Machines
    Last Post: 02-24-2009, 07:02 AM
  4. X3 column rigidity?
    By lagfish in forum Benchtop Machines
    Last Post: 12-23-2008, 04:51 AM
  5. Tormach Rigidity
    By keen in forum Tormach Personal CNC Mill
    Last Post: 08-10-2007, 01:15 AM
