588,665 active members*
5,104 visitors online*
    Mar 2006
    49
    Partner 4 Z axis issue
    Hello,
    I am in the process of purchasing a Partner 4 with Centurion 4 Controller. After Gridding the machine any time i attempt to move the Z it throws an error code 44. Which in the manual says software limit over travel. Z axis command beyond the machine limit. First thing that comes to mind would be that the z axis is in contact with the limit switch, would this be correct. My next guess is maybe the parameters are messed up. If i regrid the machine and go to jog every once in a while the z will move a little then throw the error code. Could the problem be more serious than a stuck switch. Thanks
    Mar 2006
    49
    Turns out it was as simple as I thought. z soft limit was set to .1 instead of -5.0 causing all moves to throw and error. I have a new question, I hit the e stop on the x a couple times, apparently the limit switch trips at -31.998 not after the -32.000 soft limit, Can i jog off the limit some way or is the option only to unbolt the belt cover and manually rotate it off the switch?
    Mar 2005
    171
    Hold the reset button down while you manually move the machine with the handwheel
    (pulse generator). Make sure you move in the correct direction. I not sure what is happening on your X, but if it is occuring during the grid, you probably have a sticky
    limit switch. I clean mine periodically with contact cleaner, while the machine is turned off.
    If you are moving the machine after grid is complete and it's e-stopping, you are moving the wrong way.
    After my Centurion IV completes its grid by telling you so on the screen. I switch to MDI.
    type G92 Z0. Then I type G0 X-number Y- number to move the machine off of it's limit switches for X and Y.
    I believe on your earlier question, the parameter was set correctly. After gridding the
    machine (when it tells you it is finished), You type in MDI mode G92 Z0. This tells the machine that this is machine Z zero and all tools are referenced from this point in Z for
    your TLO's (tool length offsets). This is the way my Centurion IV works.
    I believe the parameter you changed is the Z+ overtravel limit.
    my two cents,
    Ben
    Mar 2006
    49
    Thanks for the reply, changing the parameter to what the manual said seemed to do the trick and no problems so far, I will keep in mind the limit switch for any issues down the road.
  1. DIY controler X-axis issue
    By KsiR in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 03:56 AM
  2. 4th axis power issue
    By Legion99999 in forum Syil Products
    Last Post: 01-16-2008, 07:48 PM
  3. Interact 412 X-Axis issue
    By smirob in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2007, 09:25 PM
  4. Y-Axis issue
    By studysession in forum Machines running Mach Software
    Last Post: 12-28-2006, 09:11 PM
  5. A axis brake issue
    By nervis1 in forum Post Processors for MC
    Last Post: 04-18-2006, 02:46 AM
