588,117 active members*
4,936 visitors online*
Results 1 to 14 of 14
    Jun 2011
    28
    Doosan Puma 2100SY
    Anyone have any trouble running with the parts counter? It registers each part but will not run continuous.
    Ideas?
    -Mike
    Nov 2007
    188
    parts counter
    how are you ending your program. if you end with a M30 it will only run on part I put a M99 or a GOTO at the bottom to loop back to the top.
    Jun 2011
    28
    I have M99 at the bottom and it runs continuous but it still disregards the parts counter. It will count each part but it will not stop until the machine alarms out when it finishes the bar. Ideally with the job currently in there running 5 parts at a time is key.
    Jun 2004
    511
    I think that a parameter sets what trips the part counter.
    Nov 2007
    188
    parts counter
    if you go to your settings page there is a place to set parts required do you have that set to the amount you want to run
    Jun 2011
    28
    Yes, parts required is set and parts count is 0. I have tried the following codes at the end of the program.
    M30 at the end of program.
    M99 at end of program.
    M54 and M99 at end of program.
    Nov 2007
    188
    Quote Originally Posted by Mikey4865 View Post
    When you say it counts parts do you mean the lathe or the bar feeder I ask because you say in your last post that the count on the settings page was zero. if the lathe is not counting go to Parameter 6710 and look and see what number is in there if you want to count off your M99 put 99 in this Parameter
    Nov 2007
    188
    parts counter
    Jun 2011
    28
    6710 is set to M54
    I had set the parts required to 5 and it will count the parts made but it wont stopat 5 it will keep going, 6 ,7 ,8 until the bar is done.
    Nov 2007
    188
    parts counter
    I am a little confused reading my book now only thing I can think of now is to put the amount of parts you want in Parameter #6712 if that dont work hopfuly someone will jump in and correct us.
    Jun 2011
    28
    Ill give that a try, the service guy should be in today some time ill post if anything changes.
    Dec 2012
    12
    M55 Possible Solution ?
    We have an Older Puma 2000Y, not sure if the 2100 is different, but just a
    M55 is required prior to M30. Then the machine will stop When the "part count" is made. Hopefully it's the same on yours.
    Jun 2011
    28
    Turns out M54 right before an M99 is what it needed. But apparently the M30 code initiates the barfeeder, so that now has to be changed since we need to use M99 to run continuous.
    Thanks for all the help everyone sorry for the late reply.
    7
    try to program
    M55
    M99
    M55 looks like M30 (for counting parts) but program is still running continiously.
    good luck
    metalrob
    the Netherlands
  1. Doosan - Puma 240S
    By dartplayer1 in forum Daewoo/Doosan
    Last Post: 09-25-2012, 12:50 PM
  2. Doosan Puma 240MSC
    Last Post: 06-07-2012, 06:10 PM
  3. Doosan Puma 2100LY
    By D3abL3 in forum Daewoo/Doosan
    Last Post: 05-19-2012, 12:56 AM
  4. Doosan Puma Programming
    By _WALLACE_ in forum Daewoo/Doosan
    Last Post: 08-07-2011, 12:34 PM
  5. Doosan Puma MX3000S
    By broncranger in forum Daewoo/Doosan
    Last Post: 04-15-2009, 06:51 AM
