587,842 active members*
3,425 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2007
    398
    will this be an issue?
    hI all ive got these motors
    http://www.motioncontrolproducts.com...per-motors.pdf
    it says the wires are 20awg each and as you know u pair them so they share the load no heres me question i have some 1.00m2 (24awg 5 core lapp cable that im going to use so im going to cut the wires that are on the motors now as they are to short any way and solder these on instead but as the are a single 24awg wire haveing to cope with x2 20awg wires normaly will it be a problem?.
    p.s the extra core from my 5 core lapp cable will be an earth back to me driver box etc.
    cheers
    Mar 2007
    398
    please any one..... probably a very silly question hehe but im waiting to cut them and solder.
    thanks in advance.
    Jun 2007
    3735
    Maintain gauge
    Your added wires, should have the same or greater cross sectional area.
    I don't think a data cable will be up to feeding that motor.
    24220
    Personally I do not use anything smaller than 16g for motors regardless of how small the motor is, and those are fairly hefty motors!.
    Al.
    Albert E.
    Mar 2007
    398
    im thick i still dont know what the answer is hehe the wires are 24awg 1.0mm2?.
    so am i good to go?.
    Jun 2007
    3735
    When the wires become as thick as you (oops ) all will be OK.
    Mar 2007
    398
    Quote Originally Posted by neilw20 View Post
    :P no one is as thick as me.
    so just to help me understand why its ok as the wires on the motors at the moment are 20awg each then they get joined together but then some knob (me) will cut them short and attach a single 24awg wire down to the drivers so its having to cope with more on one wire?.
    Jun 2007
    3735
    Am, I thick?
    I thought 24 was small than 20. As Al_The_Man says use 16 gauge.
    Yo already have your answer. 24 is too small.
    Mar 2007
    398
    damn it this stuff was alot of moneys cant send it back now
    http://uk.rs-online.com/web/search/s...duct&R=0141362
    24220
    If you bought a reel of it, double it up
    Al.
    Albert E.
    Mar 2007
    398
    ummmm very good point looks a mess but will work.
    Jun 2007
    3735
    OK
    Now we see the cable it is OK.
    The wires are bigger than that on the stepper motor aren't they?
    I believe so.
    Now I see the motor has 8 wires. Your cable has 4.
    Are you using parallel or serial.
    You are not only going to cut some wires, but must figure which ones to join.
    Either way that wire is OK for 6 amps.
    Cut the wires after you figure how you are going to join them.
    Don't forget to plan out how the heatshrink will be used. The soldered wires need support so they don't break in service (where the solder is the wire can't flex. The soldered area must be 100% prevented from flexing.
    Stop getting confused by AWG and square millimeters. AWG is a gauge and you have to refer to tables for the sizes and ratings. At least with square mm it all makes better sense.
    Mar 2007
    398
    hi this is the motor
    and thats how i wired em red/blue,yellow/black,white/brown,green/orange
    Jun 2007
    3735
    Fast!
    That was quick. Parallel by the look of things. I think we have a time warp.
    Mar 2007
    398
    hehe i was waiting for a reply i was gutted that the wire was no good then u come back and make my day i would kiss u if i could :O.
    yes ive had them all running here on me desk they go very well but not with that lapp cable yet so now i know its good i will start it tomorrow as its 10:30pm and im tired hehe.
    edit/p.s
    thank u for all the help as i understand im not the only one here who needs it oh and allso putting up with my terrible spelling and grammer.
    Mar 2007
    398
    well ive been looking into it abit more just to be on the safe side and found this
    http://www.eland.co.uk/documents/YY%...l%20Cables.pdf
    very helpfull mines the
    offlex lapp cable 110yy
    5 core
    1.00mm2
    im well looking forward to tomorrow now so i can wire it all up im allso glad i dont have to double up the cables now as it wouldent fit me sockets o got for them.
    cheers and night all.
    Jan 2006
    628
    http://en.wikipedia.org/wiki/American_wire_gauge
    It looks like your 1.0mm2 wires are equivalent to a US 17GA. So, that looks like a good choice. Are they shielded? It says there is an earth conductor, which I guessing is the same.
    Steve
    Jun 2007
    3735
    The shield.
    If you earth the shield, earth it at the electronics end, and leave the motor end of the shield unterminated.
    Mar 2007
    398
    [QUOTE=stk2008;666868]hi yes one core is for earth back to driver box no shield.
    so connect wire in the driver box on me common earth and then on motor case.
    sorry hit wrong button.
    24220
    Quote Originally Posted by stk2008 View Post
    That is correct.
    Al.
    Albert E.
Page 1 of 2 12
  1. New to CNC, G52 issue
    By andywids in forum G-Code Programing
    Last Post: 01-10-2009, 07:09 PM
  2. another turret issue
    By Paul in OK in forum Daewoo/Doosan
    Last Post: 05-24-2007, 05:21 PM
  3. Help - Can you identify this issue?
    By Alex_Cole in forum Servo Motors / Drives
    Last Post: 05-11-2007, 01:04 AM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
