588,464 active members*
6,376 visitors online*
Results 1 to 6 of 6
    Feb 2005
    117
    program transfer problems
    I am having problems transfering or loading a large program into Mach 2 on my mill. After I load the program I find only approxiamately 1000 lines of code transfer in. The last line is usally duplicated multiple times. The machine will run up to this point and stop. If I go into the text editor I find the program complete and intact. I am stumped and any help would be appreciated.
    Thank you
    John D.
    Apr 2003
    348
    Do you have Your personalized license key file installed?
    Mach x series are limited in that they will only process 1000 lines of G-Code in the demo mode.
    Feb 2005
    117
    Thank you for the insight. The first computer that I had on the machine had port problems. The magic smoke got let out. The replacement computer we downloaded and installed mach2. I cant remember copying the licensce ovrer to this machine. I will look into this.
    Thank you
    JohnD.
    Feb 2005
    117
    Still having transfer problems
    I have copied the lincense to the computer desktop and am still having the same problem. Only 1000 lines of code will appear. Should the license be located in the Mach 2 folder?Any help is appreciated. Thank you.
    JohnD.
    Apr 2003
    348
    Quote Originally Posted by johnd
    JohnD.
    yes copy it into Mach 2 folder
    Apr 2003
    348
    You can check to see if it worked here
