588,270 active members*
11,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Reed Switches 5-120 DC 5 volt or 24 volt power supply?
    Feb 2014
    227
    I have 4 Reed switches Canfield reed switches 5-120 AC/DC model series 8000 type 2 NPN or PNP. My question I have is, My M23 board has 5 volts power to the board already on it but I have in the past wired up my limit switches to my 24 volt power supply and it works GREAT. Is it necessary to wire these reed switches to the 24 volt power supply or just use the 5 volt from the M23 board? The reed switches are for my ATC tool carousel air cylinder and for my power drawbar. The piston has a magnetic ring around it to make the connection when the piston goes under the reed switch, then trips an LED to let the user know what position the cylinder rod is in. This is needed for my M6START macro. The reason for the 24volt to the limit switches is to keep them from receiving a false signal from electrical interference.
    Here is the Website of the reed switch.
    Products Database | Canfield Connector
    Any suggestions would be great.
    Jeff
    24220
    Re: Reed Switches 5-120 DC 5 volt or 24 volt power supply?
    According to the data sheet they will operate from 5v up.
    24v is better as you say for interference suppression.
    It looks like they have a 5v buffer input so without other means you may be stuck as 5v.
    Al.
    Albert E.
  1. 60-volt Keling servos with 65-volt power supply....no go??
    By uawgmsmco in forum Servo Motors / Drives
    Last Post: 11-09-2013, 05:22 PM
  2. 48 or 36 volt power supply??
    By jaru-eri in forum DIY CNC Router Table Machines
    Last Post: 07-09-2012, 06:10 AM
  3. 5 volt power supply connection
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 05-10-2008, 09:07 PM
  4. 5 Volt Power Supply Tripping
    By murphy625 in forum Community Club House
    Last Post: 02-27-2005, 11:26 PM
  5. 24 volt dc power supply
    By natchez in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 06:31 AM
