Slaving or Syncing twin axis drives.
I am using twin screws to drive my main (X) axis gantry on my flatbed rouyer system (TRON). I'm a little confused and want to sync the (X) and (A) axis together but the manual (page 5-33) is a little unclear and does not make anty sense for me.
My M880 microstep drives have an ENA+(5v) and an ENA-(ENA) terminals. Do these need to be connected to my breakout board(C11) these can be set to 5,10,25,50,125,250 (Curently set to 10)
Does both the Dir(active low) and Step(active low) need to be ticked in the Motor outputs dialoogue box?
My x and y axis screws are 2.5mm per 1 rev. I make that 400 in the (steps per) dialogue box. and the Z Axis screw 2mm per 1 rev I make that 1000 in the (steps per) dialogue box. is this correct ?
I'd like to ask about the best setting for my steppers (Kelling 23H276-30-8B) running at 48v with current limit setting at 4.9A
I hope you dont mind all the questions but I think it's safer if I ask.
