588,235 active members*
4,454 visitors online*
Results 1 to 8 of 8
    May 2007
    15
    fanuc om not starting programs
    Need assistance please. have an Anderson cnc wood router which will not start when the cycle /start button is pressed.
    The button has tested ok. Everything can operate manually. The machine turns on fine and the ready light comes on.There are no error messages at all.
    It is as if the cycle/start button has been disabled.
    Tecnician came and he checked the ladder at the cycle/start area and said that it was working fine there also.
    Any assistance in this matter is greatly appreciated.
    Jun 2008
    1511
    Is there any door interlocks that is not allowing it not to move? Also check to make sure that your waylube is full. I have heard that this will cause no movement but also give no alarm.
    Stevo
    Feb 2009
    6028
    om
    You need to go to the diag screen and see if any reset signals etc are on. Can't believe any service guy worth his salt couldn't find a cycle start problem. Just got to search the ladder!
    Apr 2009
    108
    The first question to ask is, "Was it told to start"?
    In order to start, address G120.2 must pulse high in the ladder.
    The second question is, "Was it told not to start"?
    This will happen if the feed hold signal, G121.5, is off.
    Look at both signals in the ladder or diagnostic screen. This is a good starting point.
    Feed hold will always over ride cycle start.
    May 2007
    15
    Quote Originally Posted by Shoprag View Post
    Hi Shoprag (love the name bythe way)
    Thankyou for your assistance, you are spot on with your suggestion.
    We managed to sort the problem just before I received an email telling me I had a response on the forum. I was recommended to a Tech who specialise in Fanuc and he found that it was exactly what you said - problem with the feed hold signal.
    He went on to say it was a bad connection in the controller where the Honda connection is attached. Does that sound right to you?
    Machine is working fine at the moment.
    Once again thankyou so much.
    The more problems - the more experience gained.
    Apr 2009
    108
    Glad you got it solved. If you're interested, I teach classes on how to troubleshoot Fanuc controls. www.shoprag.com
    24220
    Quote Originally Posted by 440regal View Post
    I have seen a similar problem where power to the switch had been lost, the feed-hold signal is normally active-low, so any defect or disconnect to the switch causes a feed-hold.
    Al.
    Albert E.
    May 2007
    15
    Thankyou all so much for your assistance. It has been truly appreciated.
    Thankyou Shoprag for your link - i am most interested.
  1. Fanuc 15 M - Starting problem
    By rajappa in forum Fanuc
    Last Post: 07-18-2022, 09:45 PM
  2. problem starting up FANUC
    By gisbertz in forum Fanuc
    Last Post: 05-30-2009, 09:14 PM
  3. Starting program in fanuc 6m
    By Bolle_Ma in forum Fanuc
    Last Post: 10-17-2008, 09:11 AM
  4. If you were starting from scratch today, what programs would you invest in?
    By gimatani in forum Uncategorised CAD Discussion
    Last Post: 06-30-2008, 09:58 PM
  5. Sending programs FROM Fanuc 0-PC
    By scottsr60 in forum Fanuc
    Last Post: 01-02-2007, 02:07 PM
