587,700 active members*
3,609 visitors online*
IndustryArena Forum > Material Technology > Composites, Exotic Metals etc > problems drilling small holes in G10
Results 1 to 20 of 20
    Jun 2009
    41
    I am trying to drill .039dia holes (+0/-.0005)thru 3/8" thk G10 material. Some of the hole arrays have only a .006 web between the holes. I am having problems getting them to stay straight. I am center drill them all and have tried almost every conceivable speed/feed combination. I am drilling these on a Mazak CNC mill with a 10,000 spindle (I know, I need more RPMs). I have stub length carbide drills, I am using solid holders (no collets). The plate I am drilling is lifted off the table so the drill does not touch anything as it exits. They just will not exit out straight. Hole size is coming out spot on. I am considering a spindle multiplier, this would give me about 40,000rpm. I really dont want to spend $80k+ for a good router. Any ides??? We have do fixtures here routinely with 3000+ .025dia holes thru 1/4" cast alum with no issues. We cut composite materials here day in and day out (Durapol, Durastone, G10, Glastic, WaveMax, etc.) but this is a new product and these holes are kicking our tails.
    Feb 2008
    586
    First, are you using center drills or spot drills? I like the accuracy of a spot drill. And what about circuit board drills? Tried them? And what are the parameters / ipr / peck? Here I like a peck of half a drill diameter. Have you tried half-round drills? I don't know that more rpms are going to be your solution. Good luck with it all...
    Jun 2009
    41
    Actually it is a spot drill not a center drill, my bad. I cannot find any half rounds that small, I have looked everywhere. Have not tried circuit board drills, I'm using stub length carbide "Harvey Tool" drills. Speed/feed Ive used ranges from 8000-10000rpm, feeds of anywhere from 6.0ipm-20.0ipm, and per pecks of down to .01 all the way up to just G81 thru. Ive tried drilling the entire array to .100 deep, then coming back drilling to .200 deep and so on until thru, instead of drilling each hole thru then to the next hole. I am using flood coolant and have a 1/8" diameter stream right at the drill.
    Feb 2008
    586
    Perhaps try:
    Spot drill to .030 diameter (90 deg spot). slight dwell at the bottom. Make sure no runout on the bit.
    Drill w/carbide. Either circuit board drill or single flute of some variety. No runout either.
    4800 RPM, 3 IPM, .080 first peck, .020 subsequent. Slow the spindle after the first .200 to 4000, 2.5 IPM.
    Some of drill wander is an imperfect spot placement. If there is a bump, or the spot wandered on entry, the drill will walk a bit, too.
    Hope this helps. Someone else will chime in with different, but this is how I would approach this.
    Jun 2009
    41
    I think I figured it out. The plate I was drilling is suspended in a picture frame fixture so all thru holes can go thru. I took another pc of G10 material and mounted inside the fixture so it contacts the bottom of my plate I am drilling. This keeps the drill from ever "exiting" any material, I think the drill was wandering as it broke out the back side. I will have to use a new pc (or the backside) for every plate I drill. But the holes are coming out great now. Ill keep my fingers crossed that this is not just a fluke. I drilled about 700+ holes today in 1 plate and no problems.
    Aug 2004
    2849
    I suspect that it has more to do with board flex.
    Jun 2009
    41
    I dont think it was flex. The plate is about 20"x20" and the area to drill is only about 6"x8" and was the only area not supported in the beginning. Material is 3/8thk G10, so I dont think an area 6x8 would have enough flex to cause the drills to wander as much as they did.
    Feb 2008
    586
    What were the final parameters that you are having success with? Happy to see you having that success!
    Jun 2009
    41
    Spot drill to approx .03-.04diameter (material thickness varies across the pattern). 9500rpm, 7.0ipm, .030per peck.
    Jun 2009
    41
    straight holes now
    Here is a photo of the unit we were having the drilling problems on. What you see are pogo pins installed thru the 3/8thk G10 plate. This is a test fixture we build that is used to test circuit boards. As you can see, it was very important to have the holes straight due to the tiny and tall pins pressed into the plate. After the fix, they installed straight and none came into contact with each other. The pogos in the .039 diameter holes are not installed yet, what you see are the .059 diameter pogos.
    Jul 2010
    Pogo Test Pins
    How are the pogo pins pressed into the G10? is there a special tool, or do they press in easy with your hands or a pair of pliers?
    Thanks for the help, guys.
    I'm working on a bed of nails test fixture and I am trying coming up to speed.
    Jun 2009
    41
    The pogos have a "crush Ring" on the socket part (female) that presses into the plate, basically about a .0005 bump on the outside of the socket. There is a really tight tolerence on the hole diameter, only +.0005/-0. The crush ring is what holds the socket in place once installed. There is a special tool that must be used to install these with, it can also be used to set the height. We get our pogos and tools from QA Technology Company (603) 601-0110. If the hole is too small the probe will not float inside the socket properly, if it is too large the socket will not hold in the plate you mount them in. These are also a "1 time use", if it gets pressed in wrong, it must be removed, tossed away and a new 1 installed. Good luck, with the right tools thse are not that big of a problem, BUT with the wrong tools, they can & will be a major pain.
    Jul 2010
    Thanks, kentw. looks like I have to get an insertion tool.
    Jun 2009
    41
    another handy thing to have would be a very small rubber mallet, we use the kind that has the small replaceable faces. We use this to tap the receptacles in with. If you tap the insertion tool with something hard or metallic, we have found it tends to be too sharp of a blow and can wrinkle the top edge of the receptacle. One thing to remember, DON'T get in a hurry. "A good part tomorrow is better than a bad part today".
    Jul 2010
    Again, Thanks kentw. Your replies are appreciated. It looks like I will need an insertion tool and a small rubber/plastic mallet.
    What do you think about making the hole slightly smaller than the crush ring and slightly larger than the receptacle shaft, and then using adhesive to hold it into place? Is this unheard of? Our plate will only have about 80 pins in it.
    It seems to me like using the crush ring to hold it into place will mean that all of the pogo's will be at different heights.
    Thanks for your repsonse.
    Jun 2009
    41
    Actually, the hole you will be drilling should be a slight slip fit for the barrel and the crush ring is only about .0005-.001 larger which locks it in place. The crush ring does not set the height, it only holds it in place. We have had some that where the holes went about .0005 over size and the crush ring did not engage well enough to hold it in place, we used super glue to secure it, we also had a bottle super glue remover handy as well...just in case. It is always best to have the crush ring hold it in place, trying to glue them in place and hold an X-Y location as well as an overall height is pretty tricky. We have been doing these for years and it's a new adventure every time, 60% luck / 39% science / 1% karma. We have had plates before with upwards of 300-400 pogos in each of them, and trying to get that many holes drilled with that tight of a tolerance and in G10 was like trying to find Bin Laden, just when you think you got it, something jumps up and kicks you in the tail. Good luck hope all goes well.
    Kent W
    Jun 2009
    41
    Here is a "not scale" example of the installation
    Attached Files Attached Files
    Jul 2010
    Thanks again, Kentw.
    So from the sound of it, I will use the insertion tool and a mallet to get it started, and then use just the mallet to make the receptacle flush with the G10. This way I will ensure they are all the same height.
    It's nice to be able to gleam some experience from somebody! It is very appreciated.
    Jan 2010
    2141
    Quote Originally Posted by kentw View Post
    Sorry if this is slightly OT - I have an idea of what a "picture frame fixture" must look like (in order to keep the center area below the workpiece free of interfering objects such as a table or a drive mechanism so that you can drill through-holes), but it would help me if you could either post a picture of yours or direct me to a site that has some details about how to make one or how they function (for example, how do you clamp the workpiece in place?).
    I've done some google searches, but most of what comes back are pages detailing jigs and fixtures for making picture frames, which is obviously very different from what I'm looking for... I'd like to make and mount a CNC-based X-Y driven table on my drill press, using manual spindle Z-axis control, in order to repeatedly make aluminum parts out of bar stock with holes in specific positions.
    Thanks...
    May 2011
    Hi KentW and Monnie. I'm here to let you know that I've been building and selling pogo and fixtures for 25 years. I am a independent sales rep/pogo distributor in the Boston, MA area. We install receptacles and drill 3/8 G10 for a living with no problems. Glue is the very last resort. Yes when drilling, spot facing is good, drill in a pecking motion to get the hot G10 chip out of the hole, also use a entry material to eliminate drill walk. We mfg. and sell set tools that insert receptacles to fixed heights. Also, I distribute IDI pogos the leader in interconnect products. Give me a call if I can be of service with pogos of bed of nails fixturing.(508-222-0559) Where are you folks located, maybe I can help.
    Good luck,
    , Joe
    [email protected]
  1. drilling small holes... with router???
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 08-21-2009, 07:30 PM
  2. Drilling very small holes
    By William Demuth in forum Community Club House
    Last Post: 12-21-2008, 10:56 PM
  3. Drilling small holes in Magnesium
    By Chappyd in forum MetalWork Discussion
    Last Post: 12-16-2008, 10:34 PM
  4. Drilling small holes in Die steel
    By drk in forum MetalWork Discussion
    Last Post: 08-13-2008, 07:59 PM
  5. deep drilling small holes in aluminum
    By Fremont Dave in forum MetalWork Discussion
    Last Post: 11-25-2007, 08:03 AM
