588,199 active members*
4,967 visitors online*
IndustryArena Forum > CAM Software > Mastercam > T-SLOT CUTTER START POSITION
    Apr 2007
    142
    Hello all
    i cant figure out how to get this done, can someone please help
    ive got a special kind of t-slot that i need to cut but ive got to drop the cutter
    in a bore to begin cutting and go back to the bore to exit, and i cant see how
    to specify this start/exit position in mastercam
    any help would be appreciated
    thankyou
    Attached Files Attached Files
    Dec 2008
    3136
    -Add a point before your contour that would be the drop-in point ( in the geometry tab of your operation )
    - lead in/out parameters, check the "Use entry point" for the start ( drop in ), and "Use exit point ( for the retract position )
    - Another point after the chained geometry, is the way to alter the retract position, if it has to be different to the drop-in point
    the added point is a good, quick method for extended lead ins to profilling contours that may have to go thru extra stock
    Apr 2007
    142
    Thankyou for your reply
  1. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  2. Adding tee slot cutter to camware
    By herbet in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-23-2008, 03:56 PM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  4. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
  5. How to position cutter on a lathe and which cutter to use?
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2007, 07:26 PM
