588,246 active members*
4,636 visitors online*
    Sep 2010
    Fanuc 18-MB Travel Limits
    I am looking for help on adjusting the travel limits for a Fanuc 18-MB controller. I don't have a manual for the parameters which I would think would help me adjust the limits. The manual is B-62450E/02. Thanks Jon.
    Re: Fanuc 18-MB Travel Limits
    I am assuming you want the soft over travel limits. Parameter 1320 Plus limit and 1321 Minus limit. These values are based off of the Machine position on the position page. You type in the distance you want the machine to stop at and display the over travel alarm. Example, For X -325.500 you would type in -325500 in parameter 1321 for the X axis, the decimal point is left out of the parameter but the minus has to in there. Hope this helps
  1. Software travel limits?
    By 2xEngineer in forum Haas Mills
    Last Post: 04-15-2011, 04:34 PM
  2. Deckel DMC 60 T G7 Travel Limits
    By mikefitz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-25-2010, 07:30 PM
  3. Kondia/Dynapath 10M Travel Limits Problem
    By ballchain in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2008, 12:41 AM
  4. Fanuc OM over travel
    By malasjo in forum Fanuc
    Last Post: 03-10-2008, 05:37 PM
  5. Need help with stored limits- Fanuc 6MB
    By celtic-mfg in forum Fanuc
    Last Post: 01-11-2007, 04:33 AM
