Originally Posted by
Fixittt
these wires.... what are they going to??????????
here are pics of how I wired mine..... you only need step and DIR (numbered pins coming off of the BOB and a 5 volt PSU
I already helped him solve this days ago in my thread.
Originally Posted by Whizbang ok, I went thru all your wiring, motor, tuning and jumper settings from your pics and everything looks good
except the COM jumper on the C10.
It should be on 2-3 since keling is using it for the + connection.
That's my best guess.
I wire differently than keling so I didn't post pics to confuse you
Also, look at kelings Mach 3 setup for step/dir low. http://www.kelinginc.net/Mach3setup.pdf
Hoss
Whizbang
Hoss you are a GENIUS. x and y are now working!!
thanks for the help.
I will tackle the z axis tomorrow night.
Thanks again.
I wire mine like yours also but he is following kelings setup which works too.
To answer your question, he has the 8 wire motor connected to the Z driver directly hence 2 wires per connection.
Also he doesn't need a jumper, he has the 2 wires connected to COM going to their respective STP DIR terminal though
he may use a jumper when it's finally hooked up permanently.
Hoss
