603,407 active members*
2,298 visitors online*
Results 1 to 6 of 6
    May 2006
    238
    Smooth stepper
    Installed a smooth stepper on my IH mill and the early tests look good. It is still in beta testing so a few things need work but overall very smooth operation. I can use a laptop to run the mill and dont have to change any of the setup. Just plug in 2 parallel ports and the usb and go.
    Later DN
    smooth stepper
    http://www.warp9td.com/
    Jun 2006
    2512
    What made you go for this stepper controller rather than say Gecko.
    Phil
    Quote Originally Posted by dnelso View Post
    Later DN
    smooth stepper
    May 2006
    238
    The name is a little confusing. I still use gecko drives for the servo motors. The smooth stepper replaces the parralell ports with a usb box that simulates a parralell port. You can run a laptop instead of full size pc.It also can generate a lot nicer pulse train to the geckos.
    DN
    Jul 2009
    5
    So does it plug right into a stepper motor driver like this one?
    http://www.probotix.com/stepper_moto...ers/ProboStep/
    Or does that have to be different?
    Feb 2006
    794
    The smooth stepper is like a separate brain, it reads from mach via usb, gecko's, and all hookups are connected to simple breakout board, smooth stepper has pports which cable connect to the simple bboard's. The biggest advantage is that it has its own speed to run on up to 4ghrz or somethin like that, FAST ! Mach is set at 25,000. Mach does the math and sends streams of code to SS etc. and the servo's like the smooth fast pulse stream ! It will allow a small increase in potential speed, but I left it at 110 for velocity, even tho I got into 135 before servos complained.
    there are a few disadvantages, NO backlash yet, It can be a bit touchy, yet is showing to be a very dependable solution when all the settings are proper.
    ON a similar note, I downloaded mach 3.042.029 today and did an over install from v.020 and what a mistake ! SS went crazy, mach couldn't home machine, read WPO, couldn't probe tool. There were other problems but I just don't have a clue how to put it. I was quite surprised to say the least. I went a ways with it to see if I missed something and when machine started crashing into limits I had enough and went back to 3.042.020 and it looks like that cleared up the nasties. Any way I hope so !
    8/02 EDIT Today I reloaded the .029 version and it seems sofar that I must have done something yesterday that messed it up, today it seems so far to be fine.
    Don
    IH v-3 early model owner
    Feb 2006
    794
    It turns out there really is a problem with version .029 ! so it is back to .020 for me for a while here is the link.
    http://www.machsupport.com/forum/ind...c,12082.0.html
    Don
  1. best break out brd to use with smooth stepper brd
    By markus_detroy in forum DIY CNC Router Table Machines
    Last Post: 06-10-2008, 12:14 PM
  2. Smooth Stepper and resonance
    By IQChallenged in forum DNC Problems and Solutions
    Last Post: 05-27-2008, 01:30 AM
  3. smooth 3d surfacing?
    By Rich05 in forum Mastercam
    Last Post: 10-23-2007, 04:43 PM
  4. How smooth is techo?
    By JKuhn in forum Techno CNC
    Last Post: 08-05-2007, 02:42 AM
  5. how to smooth out stepper operations
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 10-22-2005, 02:01 AM
