I am building a 4x8 cnc plasma table. I plan on only cutting steel of a thickness of 1/4" or less, probably 1/8 mostly. But if I had to I would like to be able to cut 3/8 or 1/2, although i really dont have any means of handling material that thick except maybe in smaller pieces. I am considering the pm45 and the pm65 for the table. I have seen it said that you should get as big of a unit as you can afford. I was wondering if there would be much advantages to buying the pm65 over the pm45 if I was mostly cutting thinner material? I am not running a production shop and it will just be used occasionally when I have a project going. Any advice is appreciated thanks.
