587,930 active members*
4,114 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Siemens 840D SL 5-axis feed rates
    Apr 2014
    Hoping someone can shed some light on this. We have a DMG DMU60 eVo 5-axis mill. Trying to get Gibbs to modify the post for us and am having issues with the feed rates on 5-axis moves. Does anyone know if there is a calculation the post needs to convert the feed rate from in./min. to rev./min. in 5-axis moves? Does anyone happen to have a sample program I could look at using TRAORI?
    Thanks All
    Rick G.
    Feb 2011
    252
    Re: Siemens 840D SL 5-axis feed rates
    hi,
    If it still needed a sample program?
    Contact me at [email protected]
    Apr 2014
    Thank you Solidcamx. After pouring over manuals for weeks and testing in the machine I have found that FGROUP(X,Y,Z,B,C) & ORIWKS takes care of the problems.
    Feb 2011
    252
    Okay. Glad you solved the problem.
    I have a functional postprocessor for DMU Sinumerik840D.
    view project:
    https://www.youtube.com/watch?v=GWZT...ature=youtu.be
  1. cutter leaving feed lines at high feed rates-walter prototyp end mill
    By shimmwagen in forum DNC Problems and Solutions
    Last Post: 02-07-2014, 11:44 PM
  2. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
  3. Siemens 840D 4th axis
    By Spike13 in forum OneCNC
    Last Post: 08-03-2011, 11:59 PM
  4. Siemens 840d 4th axis----Any help would be grateful
    By nathan.gibson in forum G-Code Programing
    Last Post: 09-29-2008, 05:36 PM
  5. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
