587,354 active members*
4,788 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Siemens 840d 4th axis----Any help would be grateful
    Sep 2008
    4
    Hi all, im new so please be nice.
    I am running an ibarmia ZV50 L5000 (x5000mm,y600mm,z900mm) we have a 4th axis fully intergrated on it running parralell to the x axis so the axis is defined as the A axis.
    My problem is i have never used a 4th axis before and i am lost.
    i wont to move in both X axis and A axis at the same time to make in affect a screw of 221mm pitch, outside dia 250mm insde tread dia 180mm.
    My question how do i lock the x and a axis and how do i get the a axis to do 1 revalution for 221mm of x movement??????????
    the machine is running siemens 840d not sure which version but the machine is brand new so i am guessing the seimens bit is also new
    Apr 2005
    3634
    I run a 5-axis with Siemens 840D, I don't have any idea how your machine is setup, but the way I would do this is below.
    This assumes you are starting at the face of the part (221.0 mm) so the face of the part is X=0.0, & working your way toward the chuck is in the negative direction, the A-axis 0.0 is the center of the A-axis chuck/collet, & that you allow room to keep the tool from crashing into the face of the part & the chuck.
    When working with the A-axis & X-axis in the same line of g-code the machine goes by the rotational axis (A-axis) for it's Feed value (F=0.1), run low values on the feed or it will look like the machine is trying to cut in Rapid motions.
    This is only an example:
    G91
    G01 Z=90.0
    G01 X=-221.0 A=360.0 F=0.1
    G90
    Same code as above with comments:
    G91 ;This puts the machine into Incremental moves
    G01 Z=90.0 ;This is 1/2 the diam. of the material (bottom of the thread)
    G01 X=-221.0 A=360.0 F=0.1 ;This will move the X-axis in the negative direction -221.0 mm, & also at the same time rotate the A-axis 360.0 deg.
    G90 ;This will put the machine back in Absolute mode
    Free DXF - vectorink.com
    Sep 2008
    4
    Talking Success. Cheers
    Cheers Switcher your programme worked fine obvious now i have got it working. i was trying to only do 1 pitch so didnt see the need to use a G91 this was the only differance between our programmes. cheers for the help its much appreciated
  1. Siemens 840d how can i make???
    By cristalex_it_sr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-15-2013, 01:23 PM
  2. Looking for Siemens 840D support
    By psevin in forum Employment Opportunity
    Last Post: 12-05-2007, 04:56 PM
  3. Network and siemens 840D
    By meconer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2007, 07:56 PM
  4. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
  5. Need Help, Siemens 840d Right Angle
    By montyleeclark in forum Post Processors for MC
    Last Post: 07-19-2007, 03:23 PM
