Re: Huanyang VFD Repair
![Quote](images/misc/quote_icon.png)
Originally Posted by
mactec54
These are some of the settings that are important PD011 minimum Frequency setting I have found it's best not to go below 120Hz for this setting,(In These VFD Drives) some will run & work just fine at 100Hz is it worth to run the spindle at the 100Hz with low torque which you can't do much with, even at 120Hz there is not much torque to cut with
mactec,
Are you sure you mean 120 hz? Isn't the frequency of the line (in the US) 60 hz? So you are saying to set it twice the line frequency?
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
