587,227 active members*
3,767 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Huanyang Vfd e-stop help
Results 1 to 5 of 5
    Jan 2007
    723
    Hey guys,
    I've been playing around with a Huanyang vfd and Chinese spindle on our scratch built CNC in school. So far I've been able to run the spindles and let mach3 control the on/off and speed through the analog inputs. I would like the spindle to control the water cooling and trigger an e-stop if there is a abnormal condition such as a current overload. When working with kids, anything could happen. I figure I need as much safety equipment rigged up as I can get.
    I've read the instructions but I'm really confused as to the wiring and the pid #s and settings. Any help would be greatly appreciated.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Apr 2012
    Could you tell me how you wired your VFD to get on/off and spindle control with mach3. Is there special settings in Mach 3 to get these two fuctions to work? I currently have my spindle setup with a manual on/off switch and a pot switch for adjusting RPM. But i can't seem to figure out how to wire it and set it up to control these with mach 3. Any help would be appreciated.
    Dec 2003
    24223
    Like most VFD's this has configurable inputs and outputs, you can configure one of the unused in as an E-stop IN if you wish 09 is E-stop in.
    For the four outputs you can configure one as E-Stop on Fault out1 (PD050=02). This is a N.O. or N.C. relay output and normally could go in series with your hardwired E-stop string, which you should have, especially in a teaching environment.
    Another you could configure to turn on the cooling when a run is initiated.
    Al.
    Albert E.
    Apr 2012
    Al the man,
    Could you send me a wiring diagram how to tie the VFD with the e-stop circuit as you described. thanks for you help
    Dec 2003
    24223
    What you normally already should have is a low voltage series (E-Stop) string consisting of N.C. devices, the FA & FB N.C. contacts of the #2 output relay would be one of the devices in this string, the final result would be a low voltage coil relay with multi-contacts, these contacts would be responsible for dropping out any power relays and also a contact into the P.P. to advise Mach a E-Stop had taken place.
    The para PD051 would be set to 02 (fault detect).
    This would be the advisable way especially in a teaching environment where OSHA standards would be advisable.
    Al.
    Albert E.
  1. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  2. Huanyang HY01D523B help please?
    By Tony344 in forum Spindles / VFD
    Last Post: 10-22-2013, 01:27 PM
  3. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  4. Huanyang VFD HAL Component
    By scotta in forum LinuxCNC (formerly EMC2)
    Last Post: 08-31-2011, 04:53 PM
  5. Huanyang HY02D223B 2.2Kw VFD
    By gillyhyde8888 in forum Phase Converters
    Last Post: 09-12-2009, 12:46 AM
