Hi Steve!
I use Emc2 version 2.2.2 not the new-one (2.2.8) and if you mean this configuration
like on the picture then I tasted the same code again without any errors .
http://www.onel.se/all_files/bilder/Screenshot.png
Video with your configuration:
"http://www.youtube.com/watch?v=eJC1Y_cn0oQ"]YouTube - bpcnc
http://www.onel.se/all_files/bilder/emil.jpg
I don't have any laser
to measure accuracy.I had an error first time when I had maximum Velocity = 60 and maximum Acceleration = 62
the I changed it to maximum Velocity = 58 and maximum Acceleration = 60 and no more errors.Velocity-test
10000-13000 but I use 15000 as you can see in my conf.file.I get 3.5 meter /minute g0 which satisfy my needs.
I have got a little over 4 meter when I manually decrease BASE_PERIOD in "ini.file".
Yes,I don't use inverted output.
I use power supply 32volt 70wtt(waiting for 36volt 300-3500VA to arrive .
I use laptop celeron processor 2.4Ghz shared memory(3.5-4 meter/minute)-g540.
I use laptop Pentium III processor 850 Mhz shared memory (2-2.5 meter/minute)-g540,too.
From now I will use your configuration.
With some other controller from ebay 120 dollar Ihave got 1.87 meter/minute g0 speed with half step (400 step per rev)
To g540 driver I must give 2000 steps to rotate 360 degree with double speed on the same Laptop.
If I buy better Laptop I can increase speed with g540 but not with the same ebay card I had.
I have got best speed with Linux Puppy-older emc1 .
If people likes the newest Emc2 then I recommend using xubuntu.
Thanks!
