603,319 active members*
2,459 visitors online*
Results 1 to 5 of 5
    Jan 2007
    467
    G540 Mach3 XML File
    Here is the G540 Mach3 XML file for the REV3 G540 boards. This is courtesy of Dan Mauch at Camtronics who was one of our beta testers and was kind enough to provide this to us. If you guys have any questions about it, feel free to ask.
    The file is on the "Application Notes" page of our website and is labeled "G540 XML File".
    Application Notes
    Marcus
    Aug 2006
    674
    sorry, I'm a complete computer newb, how/where exactly do you install this file?
    Mar 2006
    115
    Go to your Mach3 folder should be c:/mach3 and this file replaces the mach3mill.xml file. But instead of overwriting the .xml with the new one I would suggest that you rename the existing mach3mill.xml to mach3millold.xml then just copy the new one into the folder. That way if you need any parameters from your old set up you can look inside the old .xml file.
    If you don't know this file contains all your setting for Mach3 and is in a special text format that can be read if opened.
    Dec 2007
    13
    Hello anyone. Mach3 & Gecko driver can be operated with MN400E controller which was made by Microkinetics corp (www.microkinetics.com) ? thanks ,Ajdcnc.
    Aug 2006
    674
    Quote Originally Posted by dfurlano View Post
    your the man! thanks
  1. Mach3 xml file for use with a laser
    By dmauch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-12-2008, 03:50 PM
  2. I need help for this file work with Mach3
    By newla in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2007, 12:13 PM
  3. Mach3 won't cut this file smoothly
    By Salty72 in forum Machines running Mach Software
    Last Post: 11-22-2007, 02:17 AM
  4. Mach3 / Bobcad V21 file help
    By Dfennell in forum Mach Mill
    Last Post: 03-25-2007, 06:48 PM
  5. Mach3 xml file
    By Ed Williams in forum Mach Mill
    Last Post: 04-08-2006, 01:50 AM
