588,126 active members*
5,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet mate RS232
    Aug 2009
    I keep getting this alarm message #320 RS232 not ready when I try to download from a PC,I know it is connected correctly because I can use the DNCB ok, can anybody help?
    Mar 2009
    1982
    RS232 port number differs from DNC-B to "punch" and also differs from "read". Communication bitrate also.
    Dec 2008
    3136
    Quote Originally Posted by Colinneil View Post
    Hi Colin, welcome to da zone
    I assume that you can send files from the control to the PC with no problems.
    Quite often the file that is to be transmitted requires a "%" at the end if the file to let the control know to terminate receiving mode, you may have to trial if the same code is required as the 1st line of code as well
    What are the machine's comms switches set to, they are set differently if running a file thru DNC as opposed to sending a file to MD1:
    Typical procedure for sending to the control
    • -on PC, open DNC program, select machine and transfer config
    • -on PC, select or open the required file
    • -on m/c, set comms switches ( if running DNC or just sending file )
    • -if running full DNC (R-method on m/c screen), cycle start should start program running
    • -if sending, <Edit>, <DNC-b>, <In>, Your Filename.MIN <Write> ---- you should be seeing the file being sent on the PC screen,--- the control screen will update or do a linefeed when entire file has been read into the control, if no % is at the end of the program <<<< the machine may freeze--- and require a reboot >>>>
    Note!!!- comm switches when setting to R-method ( full DNC ) may only be recognised after a m/c reboot
    And I don't think you can you "PIP" "READ" , but give it a try
    Apr 2012
    cant figure how to make a new post but i need help with trying to get my okuma cadet mate to communicate with my pc i have a rs 232 port but my machine dont appear to have a dnc-b so how do i send a program in
    Mar 2009
    1982
    You can receive it on OSP by "PIP>READ" command if your program size is not bigger than available free space on OSP for part programs
  1. Okuma cadet mate 4020 -OSP700M 1999
    By Taehk in forum Okuma
    Last Post: 06-21-2009, 03:23 PM
  2. OKUMA Cadet-Mate V4020 question
    By kyrbe in forum Okuma
    Last Post: 04-17-2008, 06:42 AM
  3. Okuma Cadet Graphing
    By Kart 34 in forum Okuma
    Last Post: 01-30-2008, 04:05 PM
  4. Okuma Cadet-Mate RS232/Serial port use?
    By brujo in forum Okuma
    Last Post: 06-21-2007, 01:35 PM
  5. 1999 Okuma cadet mate
    By NCcustom in forum DNC Problems and Solutions
    Last Post: 03-23-2007, 12:43 AM
